cant access drop down menus
borsht
268
So I've just been pushed from my computer which broke, to limp along on the company laptop for a while. Upon opening a certain part, the graphics display was missing. All I could see was the feature manager tree. I was able to pull down the view drop down, and turn off the tree so then I could see the graphics/part. I tried other options in the view drop down to get both showing. at some point I believe I hit a "full screen", and now I have the graphics window, and the sketch toolbar, but the toolbar is covering most of the menu dropdowns to the point where I cant access them.
Do you know the fix for this?
SolidWork Newbie since 2001
-Currently using SW2017
Inventor Newbie since 2019
-Currently using Inventor19
So I fixed that last issue, by ctrl-alt-del, and ended task. Upon restarting SW it was good again. Now I have a similar situation(visually anyway). the measure dialog box wont show me results of the measure. I tried to pick the double down arrow, and it does nothing. I've tried changing the resolution , but that doesn't fix it. Complete reboot did nothing either. Cant wait til my desktop if fixed! Any ideas?
 https://files.engineering.com/getfile.aspx?folder=38152eb7-1dc0-4e52-b83e-0e6c6d31fcdd&file=Capture.JPG
If you hit the down arrows, have you just tried to drag open the window with your mouse, as you do with any windows explorer window?
Scott Baugh, CSWP [pc2]
CAD Systems Manager
Evapar
"If it's not broke, Don't fix it!"
faq731-376
Thanks Scott. I had tried that to no avail. I ended up fixing it by persevering with clicking the double down arrow. There was a very small envelope of where it would react. Finally I found the sweet spot, and got it working again. But I have even better news. Dell put on it's listening ears and fixed my desktop, so I'm done fighting with the laptop and back to a real machine. Hopefully no more puzzlers for a while.
