Contact US
[ASK] Standard in ASTM that Provides Info Requirement Only for Hardness Value for Alloy Steel ?
Sirs, as title of this thread.
Is there any ASTM standard that provides requirement information only for hardness value for alloy steel in generally ?
Hopefully someone that expert on this may help me, due i need reference for my material specification, and what i need is only for hardness, more better if the hardness scope is for general alloy steel not only for specific alloy.
Thanks in advance guys
RE: [ASK] Standard in ASTM that Provides Info Requirement Only for Hardness Value for Alloy Steel ?
No, you don't want just hardness. I give you steels heat treated differently that have very similar hardness but radically different Yield strength, toughness, fatigue, and so on.
Since you are talking about more expensive steels I guess that it might matter to you (or your customer).
You should use specs that lay out the required HT process (such as Q&T), and have required strength and ductility at a minimum.
If hardness is all that matters then look at plain carbon steels.
Any change in C and alloy content will change how a steel hardens and will require separate guidelines.
Sorry mr.Ed, i forgot to mentioned that heat treatment requirement minimum is using Quench and Tempered (QT)method.
So is there any standard of ASTM or else that provides information about hardness of alloy steel in general using QT method ?
Many thanks before
No. The ASTM specs are not that procriptive. They are application (property) oriented, not process oriented.
You would need to identify product forms, the acceptable specs, and then which alloys and properties you want.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
