3-way Ball Valve CV Calculation Formula
Does anyone know how to mathematically or thru CFD calculate the CV of a 6in 3-way T-port ball valve? See attached for reference..
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: 3-way Ball Valve CV Calculation Formula
Given you can have all sorts of different permutations i suspect this is a measurement only derivation.
Can't you use a T for equivalent length?
It's not often you see this sort of valve or tee used to take in flow from both directions though and then out through one port if that's what you imply.
