Seismic bracing for Non Structural Components per NBC Article 4.1.8.18.
Hi all, I wanted some guidance from the experienced engineers here. I am reviewing some pipe supports at a waste water treatment plant for compliance with seismic requirements specified in the National Building Code of Canada . I have attached a picture showing some of the supports.
The design seismic lateral load that I have calculated on the pipes is 21 lbs. This load is applied in the horizontal that results in the most critical loading for design of the supports. The current supports are just vertical and I believe are not adequate for seismic requirements as the transverse load may put the threaded rods into bending. I don't have experience in the design of seismic supports for piping. My approach for the design of the supports thus far has been:
1. Look at Unistrut Seismic bracing catalogue.
2. Choose product and determine maximum spacing for transverse and longitudinal bracing.
3. Determine capacity of the seismic supports for the design loads I have calculated.
4. Specify bracing system, spacing and details.
The problem I am running into however is the data provided on the website is for steel pipes. I am not sure how to figure out maximum spacing for bracing requirements. Basically I am kinda stumped. Some bracing ideas would be awesome. :)
Here's some input data:
1. The piping is a double containment system consisting of a 3" PVC Sch 40 pipe within a 6" pipe of the same material. The 3" pipe contains Ferric Chloride acid with a density of 1.46 g/cm3.
Any input is appreciated.
RE: Seismic bracing for Non Structural Components per NBC Article 4.1.8.18.
I don't know which system you are curious about, the off the wall hanger system, or the roof hanger? For the roof hanger, you can do a research on product from this site, Link. For the off the wall system, you need to find out literatures on PVC pipe support, then work with Hilti. Or, get the standard as referred by this site. Link.
Another good pipe hanger producer is "unistrut", which is better than Hilti in my opinion.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Reshoring Prototyping and Production
In this whitepaper, we'll provide insight into why and when it makes sense for U.S. manufacturers to reshore prototyping and production, and how companies can leverage the benefits of working with local design, prototype, and manufacturing partners during the pandemic and beyond. Download Now
Engineering Report - Top 10 Defect Types in Production
This 22-page report from Instrumental identifies the most common production defect types discovered in 2020, showcases trends from 2019 to 2020, and provides insights on how to prevent potential downtime in 2021. Unlike other methods, Instrumental drives correlations between a variety of data sources to help engineers find and fix root causes. Download Now
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
