Contact US
Lubricant Latent Heat
my client is replacing a compressors oil cooler, for a bigger one.
During HAZOP analisys was defined to design a fire case PSV for oil side...
In my point of view, i should consider the heat imput as a fire case, but calculate capacity as a thermal relief, but, actually, its not the client's ideia!
Does any one has any data on Lubricants? Mainly latent heat?
The oil is a normal ISO VG 46. Its being very difficult to find information, even contacting suppliers...
RE: Lubricant Latent Heat
Thanks Obturator.
I took a look in cheresources, but the thread is not finished... But... i'm trying to find an S.G. vs Latent heat in some bibliography. I guess i need som old books...
I was hoping that the suggestion on the chersources would help. Maybe your answer is in this old publication file:///C:/Users/mazbo/Desktop/GOVPUB-C13-da7a968e895631e1fad8cf9c2aef73e1.pdf
Per ISO-4126, only the term Safety Valve is used regardless of application or design.
Vaguely recall the API 520 recommendation to use 40Btu/lb as latent heat of vaporisation when it is not known.
great!
50, actually! Thanks for the tip!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
