DIB-1 Valve Cavity Relief
Do DIB-1 valves ALWAYS require a means of relieving cavity pressure (either automatically or manually as per API 6D)? My confusion is, for liquid service there should always be an LRK as thermal expansion is likely, but in gas service, is a means of relief required? API 6D is kind of vague as it says if fluid trapping in the cavity is possible (which is always the case with any valve?), and what if it is a CSA valve? My understanding is that due to the DPE seats it must have some means of relief (auto or otherwise) in case u/s seat fails for whatever reason.
RE: DIB-1 Valve Cavity Relief
If the valve is in gas service and you can show that from max operating pressure the gas can't create pressure bother than the valve design pressure die to temperature increase then no, I don't believe it needs a pressure relief. But liquid yes.
Thus, the answer is NO, it's not always required, but it's highly desirable.
Luke | Valve Hax | https://valvehax.com/
Hitokiri, there are lots of issues we are experiencing associated with tubing (namely tubing relief commonly occuring and the valve becoming essentailly a DBB afterwards as pressure is required on both sides of the seat to hold and oftgen the tubing is being ran to the incorrect side; U/S vs. D/S confusion, tubing freezing, plugging, leaking etc.) so we are trying to avoid DIB-1 valves as they don't add any value in standard applications/operations when the relief tubing is either piped u/s or d/s..
