Variation in ride height with sprung mass, ADAMS Car
Is it possible to determine the ride height variation (or spring deflection) with changes in sprung mass and center of gravity in ADAMS/Car? I have the value of the spring deflection from full-rebound of the vehicle to static condition(@ ride height) both physically measured and also hand-calculated. Since these values vary, I thought I would validate these using ADAMS/Car but I am stuck.
Is there any simulation in ADAMS/Car that helps me find out the spring deflection @ full-rebound and @ static condition
RE: Variation in ride height with sprung mass, ADAMS Car
Sure, use >Simulate>Suspension Analysis>parallel wheel travel, or >Simulate>Suspension Analysis>Static load. Alternaitvely just run a straight line maintain at a low speed, iterate the loads to give the desired wheel loads..
I have some preference for the latter as most of my work is dynamic and there may be obscure difference in how the assembly is built for static and dynamic events.
However I do not use the vanilla version of Car so I can't really be of much help.
Cheers
Greg Locock
Thanks for the reply @GregLocock
But I want to know the spring deflection at the static condition due to the vehicle's sprung mass only. Can you suggest me any method to find out this value in ADAMS/Car?
So you find, or write, a request that measures the length of the spring.
Frankly I'd be amazed if it wasn't a built in request, but as I say I'm not a Car user. Oh yes, one minute's perusal of the results comes up with nsl_ride_spring_data with channels including displacement and force. I expect there are others.
Cheers
Greg Locock
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Solutions Brief - Protecting and Rescuing On-Ground Personnel
Keeping our warfighters safe and delivering them a competitive advantage is a key goal of departments of defense around the world. It’s a goal shared by embedded computing manufacturers like Abaco: we never forget who we serve.This case study describes how a major international contractor integrated an Abaco single board computer at the heart of its CAS/CSAR solution. Download Now
Datasheet - Top Enhancements Creo 7.0
PTC's Creo 7.0 has breakthrough innovations in the areas of generative design, real-time simulation, multibody design, additive manufacturing, and more! With Creo 7.0, you will be able to design the most innovative products faster than ever before, keeping you on the cutting edge of product design and ahead of your competition. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
