Macro to create a viewpoint 1
AlexMorasan
Automotive
MX
Hello everyone
I have to create a macro that will allow the user to create an specific viewpoint of the main assembly so the user can take an screenshot ( the screenshot is use to update our assembly handbook).
I have analyzed the DMUInfEngineeringView file and with that I have created my own code.
Language="VBSCRIPT"
Sub CATMain()
Dim ProjectionM
Dim FocusD
FocusD = 837.729
' Get the viewer
Set oViewer = CATIA.ActiveWindow.ActiveViewer
' Get the viewpoint
Set oViewpoint = oViewer.Viewpoint3D
Dim origin(2)
Dim sight(2)
Dim up(2)
M = 2568.767
N = -301.194
P = 323.169
X = 0.972
Y = 0.130
Z = 0.195
U = -0.200
V = 2.627
W = 0.979
' Change the viewpoint
oViewpoint.PutUpDirection Array(U, V, W)
oViewpoint.PutOrigin Array(M, N, P)
oViewpoint.PutSightDirection Array(X, Y, Z)
oViewpoint.ProjectionMode = catProjectionCylindric
ProjectionM = oViewpoint.ProjectionMode
MsgBox ProjectionM
oViewpoint.FocusDistance = FocusD
' Update the viewer
oViewer.Update
oViewpoint.GetOrigin origin
oViewpoint.GetSightDirection sight
oViewpoint.GetUpDirection up
For i = 0 to 2
MsgBox origin(i)
Next
For i = 0 to 2
MsgBox sight(i)
Next
For i = 0 to 2
MsgBox up(i)
Next
Set oViewpoint = Nothing
Set oViewer = Nothing
End Sub
However my problem is that instead of getting the viewpoint that I need I always get a rotated version of my desired viewpoint.
Example:
This is the viewpoint that I need, I already know the coordinates for the origin, the sight direction, the up direction and the focus distance (I use another macro to get this data)
This is the viewpoint that I get, as you can see the viewpoint is slightly rotated.
Currently the code is in CATscript but the final version will be in VBA.
I would really appreciate any help you can give me.
Thanks in advance for your support.
Alex
Hi.
Have you tried your approach on another assembly? What CATIA version do you use?
Hello Little Cthulhu
Thank you for taking the time to answer my post.
Yes I have tried in another assemblies but I still get a different version from my objective viewpoint.
Right now I am using CATIA Version 5-6 Release 2018 Service Pack 3
Are you sure about the way you retrieve your hard-coded values?
I can't reproduce it in R25. I ran script below up to breakpoint, moved sight and then continued execution.
Viewpoint returned back to initial position as expected.
Code:
Option Explicit
Sub CATMain()
    Dim v3d As Viewer3D: Set v3d = CATIA.ActiveWindow.ActiveViewer
    Dim vp: Set vp = v3d.Viewpoint3D
    Dim fd: fd = vp.FocusDistance
    Dim origin(2), sight(2), up(2)
    vp.GetOrigin origin
    vp.GetSightDirection sight
    vp.GetUpDirection up
    Dim zm: zm = vp.Zoom
    ' BREAKPOINT HERE
    vp.FocusDistance = fd
    vp.PutUpDirection up
    vp.PutSightDirection sight
    vp.PutOrigin origin
    vp.Zoom = zm
    v3d.Update
End Sub
Hello everyone
My apologies for taking so long to answer but because of COViD-19 we weren't allowed to go to the office and so I was unable to work on this macro.
Nevertheless I am finally back and I have manage to correct my macro.
Unfortunately I don't know the reason but every time I run the macro the UP Direction vector changes , so my solution was ( probably not the best solution but it works) to modify a second time the UPDirection to correct the viewpoint.
The main part of the code related to the viewpoints is like this:
Option Explicit
Sub CATMain()
vp.GetOrigin origin
' BREAKPOINT HERE
vp.PutOrigin origin
vp.Zoom = zm
'In this part I modify for a second time the up direction to correct the viewpoint.
v3d.Update
End Sub
thank you for your support and once again my apologies for letting this thread open for so long.
Alex
Giving you a star for giving us a feedback despite the circumstances!
Thank you for the star.
The main idea of this macro was to create a matrix of viewpoints in excel to make it easier to update the assembly handbook that we deliver to our client.
So, if anybody is in need of something similar I will be happy to share my code with you.
Please let me know if you need a sample of the code.
Hi AlexMorasan,
I am working on a task to get snips of four views (ISO, Front, Top, Side)of the product from CATIA.
I need to do it in CAA, but your vb code will help me get the math right.
Can you share the sample code with me?
Thanks for the help.
Hi Sardeshmukh
My apologies for answering until now, but I was on vacation and I didn't see my mail until now.
Of course I can provide you with the code, just tell me which part you are interested in ? the part to acquire the viewpoints or the part to change the viewpoint?
I am sorry if I can't share all the code but it contains information from my company that I can share I hope you understand.
Promise I will give you the information as soon as you reply.
By the way I have a question, what is CAA?
Thanks in advance I am looking forward for your answer
Hi AlexMorasan,
Thanks for the reply. I am interested in the code for changing the viewpoints.
CAA is a framework based on C++ which is used to customize CATIA.
Ex: CAA can be used to create toolbars, commands, one can deal with mechanical modelling, geometrical modelling etc.
Thanks again for the help
Hello Sardeshmukh
Here is the part of the code, I hope it will be useful for you.
The macro that I made uses an userinterface, in this UI the user have to write the viewpoint that he needs (this viewpoints are related to the pictures of the assembly handbook). The coordinates of that viewpoints are stored in an excel file, so the macro only have to look for that specific viewpoint and retrieve the information.
I hope the code is understandable but if you have any question please feel free to ask, I will try to answer ASAP
Private Sub Go_ToFile_Click()
Dim v3d As Viewer3D
Dim vp
Dim fd
Dim last_pos As Integer
Dim stock_pos As Integer
Dim page As String
Dim stock_exist As Boolean
Dim PDM_file As String
Dim PDM_Project As String
stock_pos = 0
stock_exist = False
page = PDM_Page.Value
PDM_Project = Project.Value
Dim oExcel As Excel.Application
Set oExcel = CreateObject("Excel.Application")
Select Case PDM_Project
Case Is = "XXX"
'---Launch Excel---
On Error Resume Next
'if Excel is not open then Launch Excel
oExcel.Workbooks.Open ("XXXXX")
Case Is = "XXX"
'---Launch Excel---
End Select
PDM_file = PDM_Zone.Value
oExcel.Worksheets(PDM_file).Activate
oExcel.Visible = False
On Error GoTo 0
'get the curren Excel sheet
Dim OWB As Excel.Workbook
'If there is already a workbook, set it as active, otherwise create a new workbook
If oExcel.Workbooks.Count <> 0 Then
Set OWB = oExcel.ActiveWorkbook
Else
Set OWB = oExcel.Workbooks.Add
End If
last_pos = oExcel.Cells(1, 15)
For stock = 1 To last_pos
If page = oExcel.Cells(stock, 1) Then
stock_exist = True
stock_pos = stock
Exit For
Else
stock_exist = False
End If
Next stock
If stock_exist = True Then
For origin_index = 0 To 2
origin(origin_index) = oExcel.Cells(stock_pos, origin_index + 2)
Next origin_index
For sight_index = 0 To 2
sight(sight_index) = oExcel.Cells(stock_pos, sight_index + 5)
Next sight_index
For up_index = 0 To 2
up(up_index) = oExcel.Cells(stock_pos, up_index + 8)
Next up_index
fd = oExcel.Cells(stock_pos, 11)
zm = oExcel.Cells(stock_pos, 12)
vp.PutOrigin origin
vp.Zoom = zm
v3d.Update
v3d.Update
Else
MsgBox "That page does not exists yet, please another page"
End If
oExcel.Workbooks.Close
Set oExcel = Nothing
End Sub
Do you know some bibliography where I can learn more about CAA? or an specific link? it seems interesting and I would like to improve my macros.
Alex
