Hello from wind ravaged Iowa,
I am starting to get calls to review wind damage in our area. The building I looked at today had some interesting damage. The bottom chord of the open web steel joists was kinked between the rows of bridging. Bottom chords braced at 1/3 points do not like being in compression when the roof is sucked up by 110mph winds and force reversal occurs. Derecho - 1, Steel Joist - 0
I've designed joist reinforcement for added loads before. Due to the kink, using rods in the leg of the angles doesn't really work. There were also a few locations where at least one side of a web weld had broken loose from the bottom chord angle. For this situation, I have 2 options that immediately come to mind:
(1) shore the joist, remove the damaged bottom chord, install new bottom chord (time consuming considering there are about 36 joists that need repaired.)
(2) shore the joist, plate the bottom side of the deformed chord creating a splice to span the damaged area
Does anyone else have a better idea? I know I would also have the option of contacting the manufacturer for a repair, if I could determine who that was.
TIA!
TIA!
