How does my profession translate into English
VladimirWH
Petroleum
RU
Hello.
I need some advise about how my current profession translate into English.
I'm work CAD (autocad/inventor/kompas). Most of things i'm design in 3D.
Recently design piping for chemical injection station (skid). Also I work on pumping stations, make steel constructions for it. It's call shelter - steel construction with SIP panel walls.
Sometime I choose equipment for piping system: guage, pump, valve, PSV and other.
Also design tank with and without pressure for chemical and water treatment.
Also can design P&ID.
So, I register in linkedin and call my self "Piping designer". Is that close to my work?
Piping designer is what I would use.
I'm pretty sure you could find some other titles but I think most engineers would listen to that and then say " So are you really a piping designer?"
