Ball Valve's Seat Design Methodology
Does anyone know how to design the geometry of the seat for ball valve? Any design calculations or steps recommended to accurately design soft and metal seats??
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Ball Valve's Seat Design Methodology
I bought them because I was working on small ball valves for refrigeration.
All the other features of the valves had been messed up along the way, but the seats worked reliably.
They comprised a machined TFE ring, with squarish 'corners', formed as chamfers in a screw machine (and possibly tumbled to remove burrs, I don't remember), that was crushed into shape as the valve was screwed together axially. I.e., the seat surface was produced by the ball itself, inducing a LOT of plastic deformation in the originally square sectioned blank. No equations found useful.
Larger valves typically have complicated chamfers where the seat will eventually be; I'm not convinced it does much good.
Mike Halloran
Corinth, NY, USA
no one is going to share that proprietary calculation easily. It starts from the ball out.
Luke | Valve Hax | https://valvehax.com/
