Advice Required.....
Ryan_DXB
AE
Hi to all the gods of Structural Engineering.
I come to you today as a lonely peasant who has no experience in the essence of the engineering myth and legend that is around us on a daily basis.
I seek council on a structural issue for a new business venture that I have......
I am interested in engaging with a structural engineer who may be able to review a design that we have measuring 5m (W) x 5m (D) x 2.5m (H)
Basically I need to understand if our design with specific regards to the roof structure can support our sandwich panel @ 27.4kg/m2 as well as maximum snowfall weight regulations (60kg) as set by UK Building and Planning regulatory body.
Our frame structure is made of a galvanized steel tubes each measuring 1000mm in length. These are joined using ball clip couplers.
The reason for this design is that I require my frame to be man portable, easy to assemble and be interchangeable at 1 Meter intervals. I.E 5m x 5m/4m x 4m/3m x 5m etc
I am interested to speak with any Structural Engineer moving forward in order to obtain a consultancy proposal for review and advice on our current design.
Looking forward to hearing back from you,
Thank you muchly,
Kind regards
Ryan
 https://files.engineering.com/getfile.aspx?folder=2b8c2e81-9e06-4beb-8247-49d83dc3a3fa&file=sandwich-panel-spa-e-life-energy-en-gb.pdf
