Contact US
Welded Beam Ridge Connection
I'm cutting and welding a steel W section to support a ridge beam. The roof slopes 4:12 each way. I'm looking for a prequalified CJP welded connection for the flanges.
All of the prequalified connections are for either parallel plates (butt joint) or plates at ninety degrees (T or C joint). Any suggestions for a prequalified joint for non-parallel plates?
RE: Welded Beam Ridge Connection
Assuming AWSD1.1, pre-qualified butt joints are allowed to skew from 135deg to 180deg. Check out note #10.
Thank you. I knew it had to be hidden in there somewhere.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
