Catia Macro Change Units
Catia Macro to Change Dimensions Automatically
i want to create a macro to change dimension from any unity to any unit (Like mm to m or mm to cm)
i can select dimension and change visProperties and one dimension but how do i change the unit of several dimensions
here is the macro
Option Explicit
Sub CATMain()
Dim draDoc As DrawingDocument
Set draDoc = CATIA.ActiveDocument
Dim draSheets As DrawingSheets
Set draSheets = draDoc.Sheets
Dim drawDheet As DrawingSheet
Set drawDheet = draSheets.Item("Sheet.1")
Dim views As DrawingViews
Set views = drawDheet.views
Dim draDimensions As DrawingDimensions
Set draDimensions = views.Item("Front view")
Dim oSel As Selection
Set oSel = CATIA.ActiveDocument.Selection
CATIA.ActiveDocument.Selection.Clear
oSel.Search ("Drafting.Dimension,all")
MsgBox oSel.Count
End Sub
RE: Catia Macro Change Units
Here is my vb.net code to do this. Has been pretty robust so far. I'm sure you could easily adapt it to change other units as well.
Sub unitToggle()
Dim knowledgeSheetSettingAtt1 As KnowledgewareTypeLib.KnowledgeSheetSettingAtt
Dim settingControllers1 As INFITF.SettingControllers
Dim unitsSheetSettingAtt1 As KnowledgewareTypeLib.UnitsSheetSettingAtt
Dim setUnitType As String
Dim unitType As String = ""
Dim double1 As Double
Dim double2 As Double
settingControllers1 = MainForm.CATIA.SettingControllers
unitsSheetSettingAtt1 = settingControllers1.Item("CATLieUnitsSheetSettingCtrl")
unitsSheetSettingAtt1.GetMagnitudeValues("LENGTH", unitType, double1, double2)
If unitType = "Inch" Then
setUnitType = "Millimeter"
Else
setUnitType = "Inch"
End If
unitsSheetSettingAtt1.SetMagnitudeValues("LENGTH", setUnitType, 4, 3)
knowledgeSheetSettingAtt1 = settingControllers1.Item("CATLieKnowledgeSheetSettingCtrl")
knowledgeSheetSettingAtt1.SaveRepository()
knowledgeSheetSettingAtt1.Commit()
unitsSheetSettingAtt1.SaveRepositoryForUnits()
unitsSheetSettingAtt1.CommitForUnits()
End Sub
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Functional Prototyping Using Metal 3D Printing
Functional prototypes are a key step in product development – they give engineers a chance to test new ideas and designs while also revealing how the product will stand up to real-world use. And when it comes to functional prototypes, 3D printing is rewriting the rules of what’s possible. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
