TDC3000 FAST Load Issue
R_Byrne
Petroleum
GB
When loading up system from FAST Start ZIP the personalities load then asks for NCF file , i had to load from an old checkpoint using file transfer and putting the &ASY directory on a different ZIP, also asked for &CUS.
This is after having issues where the system would not see any of the ZIP drives.
LOAD
N,1,2,3,4,X
Selected 1 and got error
ERR -1
???? N,1,2,3,4,X
no errors on K6LCN board, EPDG I/O replaced and ZIP drive replaced....suspect power supply (5v) but no errors....FAST LOAD HAS WORKED FINE IN THE PAST. Deffo a hardware issue but cant seem to pin this one down (SCSI cable?)....its an old UWS on a test system,,,only connected to HM & NIM so very simple...
