Signed/directed deviation?
I am measuring the relative deviations of some variables according to a formula given as follows:
Dev. % = 100 * (Value_Predicted - Value_Measured) / Value_Predicted
For some variables, when Dev. > 0 it means performance of the process is improving (i.e. the higher the Dev., the higher the performance).
For some other variables, it works the opposite way (i.e. the lower the Dev., the higher the performance).
I am displaying the Dev. of all variables in a X-Y chart.
On the X-axis there is <time T(s)> and on the Y-axis the deviations <Dev. (%)>.
I want to make it so that on the Y-axis, instead of displaying <Dev.> I would use a new indicator in such a way that an increase always corresponds to performance improvement and vice versa. Thus I corrected the original deviations as follows:
Dev_New = sign_function() * Dev_Original
sign_function() would take (1) or (-1) to reverse when it is needed.
My question, how do you call this new indicator: Dev_New?
- Directed deviation
- Signed deviation
Any suggestions would be appreciated.
- Signed deviation
If you plan an escape, you must succeed as if you fail, you will be punished for trying. Never say or write down your plan. Heart is the only place where secrecy is granted.
RE: Signed/directed deviation?
Percent
Diminishment
Decline
Decrease
Reduction
...for those Y values below the X axis.
Skip,
Just traded in my OLD subtlety...
for a NUance!
