HOW TO DEFINE THE PROPERTIES OF MATERIAL FOR WELDED MESH
Luis camposano
11
Good evening, In ETABS we can define the material for the reinforcement with a material, for example, for Fy = 4200 Kg/cm².
Someone could indicate how the material for welded mesh is defined with a Fy = 4900 Kg/cm² (70,000 Lbs/in²).
Is the type of material also defined as reinforcement?
regards
