Bearing Set up Identification
Hello everyone,
I hope you're all well.
I am trying to figure out what the bearing set up is in the photo attached. Please could I get any advice?
As far as I can see, starting from left to right, the set up is:
- A bearing end cap (I am confused, because it has a central tightening screw. Perhaps it's an adapted bar end plug for the bearing shaft?).
- A pillow block bearing (welded to back support pad).
- Bearing lock collar (out of view, but I have confirmed this viewing other videos).
- Brass coloured bushing or sleeve?
- Through hole plate welded to base frame.
- Box section end and pipe within? Box section attaches to seat pad.
- Through hole welded to base frame.
- Brass coloured bushing or sleeve.
- Bearing lock collar.
- Pillow block bearing.
- Bearing end cap.
- Obviously, there is some sort of shaft running through the whole set up.
Purpose of this set up: It joins the gym bench's back support and seat pads to allow them to adjust on the same hinge.
Any help would be greatly appreciated.
J
- Bearing end cap.
J
RE: Bearing Set up Identification
Thanks for your reply.
I am looking for advice on if the bearing set up and its components I have listed are correct. For example, I have suggested from left to right, the first component is some sort of end cap with a central fastener screwing in to the shaft. However, I am looking for confirmation or suggestions if this is correct. Perhaps it is an shaft end plug instead. Another example, is I think the second component is some sort of housing - a pillow case bearing.
Any help, suggestions or confirmation on my suspicions of the setup would be greatly appreciated.
Many thanks
J.
