Section lable
Sa-Ro
IN
How to stop section label letter continue in second sheet.
Ex:
Sheet 1: Section label A to D.
After copy paste the sheet 1, all section label in sheet 2 changed as E.
Sa-Ro,
Can you describe your problem more clearly? Section labels need to be unique across all the pages of your drawing.
JHG
@Sa-Ro
I don't know when this option was added but in 2020, when copying sheets you are given the option to rename the label or not. Either way, the label can be edited after it is created
If the section is exactly the same, but copied for clarity of dimensioning, the label should clearly state such.
