Design Spring for seat seating in Trunnion ball valve
Hai everyone if you have more experience in valve industry or manufacture please i need help
im newbie in valve industry
maybe someone in here can calculate / modification for spring coil or belleville spring that needed for seat seating in Ball valve with trunnion design ?
RE: Design Spring for seat seating in Trunnion ball valve
Per ISO-4126, only the term Safety Valve is used regardless of application or design.
Design calculation is built based on the concept or geometry of the design.so, we need their geometry.
I trust "the obturator" Understands!!!
G Mohan
Spring Force Required = Target Sealing Stress x Seat contact surface.
Usually Springs are designed for low pressure sealing, depending on design.
This is different for everyone.. so not sure why that question is being asked on a public forum. while mohan should not be selling his services, consultants is basically what you need if you really want a tailored solution.
Luke | Valve Hax | https://valvehax.com/
