Contact US
bs en iso 15614 and bs en iso 9606-1
hello guys
am learning more on welding standards /specs. I have some question's if you have the time to help and explain the questions that am asking please. as I say am learning and trying to under stand more
question one- if one welder takes a test (PQR) 15614- and passes and if a second welder takes the same test will the second welder's standard come under 9606
question two- passing a test on plate to plate does that cover a welder to weld box section to box section because plate will cover pipe in position over 500mm dia
question three- is it possible to take a test to 9606 standard only or does 15614 have to be achieved first before taking 9606
thank you for your time
RE: bs en iso 15614 and bs en iso 9606-1
(1) is the test a welder performance qualification, then it must be done according to 9606-1. If the test is to qualify a pWPS, then you need to follow the 15614-1.
If a welder welds a piece in order to qualify a pWPS and additional details have been taken care of, he can qualify the pWPS (so obtaining a WPQR according to 15614-1) AND he gets a 9606-1 WPQ.
(2) Depends what you call a box section. This is a tricky one, because square or rectangular sections are commonly seen as (round) pipes with diameter = the smallest dimension of the SHS.
Buy yes, generally a FW (plate/plate fillet weld) will cover welding box sections, because these are essentially plate to plate fillet welds.
(3) Both can be done independently. There is no order. No relationship between both as you mean in this context.
There is however a need to have a (p)WPS for both, but a pWPS is accepted for a WPQ.
thank you for responding with good answers
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
