True position of a slot
3
Hi
Please see attached quick sketch ,
Datum A would be one of the planes ( not shown )
Regarding the positional call out for the slot .
What would be the best way to think about / understand the basic dimension of 50mm.
It looks like a centre axis between the two radii, Although i hope i would be correct in saying Datum Feature would be the mid plane derived from the two small planes on the slot
R
RE: True position of a slot
You are not controlling the location of the slot in the horizontal direction.
The ASME Y14.5 standards gives the exact interpretation of that condition; what do you think based on what is in the standard?
"What would be the best way to think about / understand the basic dimension of 50mm."
The true position of the longitudinal center of the slot (center of the geometrical theoretical geometry). By the way, the location of the slot is not defined in the direction of the 50 basic, the position tolerance you show doesn't control that.
3DDave + Burunduk
Thanks for your replies ,
I was completely unsure why the 50mm basic is placed .
The position of the slot in relationship of the hole , what is the best way show this on the drawing ,
If this was two holes , yes the 50mm basic would make sense to me ,
R
50 basic should be there. You need another position FCF to control the slot's location in the direction of 50 basic.
See figure number something in ASME Y14.5-something.
Burunduk
I understand now about the two FCF placed on to the slot .
R
Quote (Rwelch9, 24 Jun 20 07:10)
You have not shown a datum feature symbol applied anywhere to the slot, however datum features are PHYSICAL features on your part that you can touch - datums are theoretical points, lines, and planes derived from datum features. The distinction is important, and determination/derivation of either depends little on how the basic dimensions are applied ie: to the theoretical center plane/line (though of course, one must have a valid combination of basic dimensions) and much more on how the feature itself is defined and how the datum feature symbol is applied. If the datum feature symbol were applied to the width between flats, your datum feature would be the width. If the entire slot were defined with an all-around profile tolerance and the datum feature symbol applied to the profile tolerance, the datum feature would be the entire slot as shown by Y14.5-2018 fig 7-3(f) linear extruded shape.
Quote (Burunduk, 24 Jun 20 08:17)
...................................or Y14.5-2018 fig 10-35
chez311
I have forgot to add the datum feature symbol to the slot width , which would have been Datum C
Thanks for the reference to the 2018 version.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
