I just had a structural engineer come out to verify that a pair of perpendicular interior walls were or were not load bearing before taking them down but I wanted to get a second opinion.
I had been told by our home inspector, who is also a structure engineer, that generally with floor trusses most of your interior walls are not load bearing but referred me to his company for an evaluation to confirm.
The engineer came out and immediately said that because the trusses had a double vertical 2x4 right over top of an interior perpendicular wall that the wall was load bearing. There was also a single 2x10 (roughly 3ft long to cover the width of the hallway) attached to the three trusses that go over our hallway, where there isn't a perpendicular wall, that he thought was acting as a header. It also has two 2x4 skirts attached to the bottom of the 2x10 on both edges that look like they're in place to attach the ceiling drywall which makes more sense to me than using a single 2x10 as a header.
After he left I removed more of the drywall in the stairwell to get a better view of the trusses and it looks like the truss is floating above the perpendicular wall that he believes is load bearing. In one of the attached photos you can see the top plate of that wall with a gap under it and the ceiling drywall on both sides. Could this still be a load bearing wall even though I can't see anywhere that the wall is actually touching the trusses? I don't know how any weight could be bearing on that wall with the air gap there but maybe the builders just improperly built the wall and didn't do it to the spec that the trusses were engineered with.
Here are some general specs.
Truss span(running front to back of house): 26ft
Truss spacing: 16" o.c.
Truss depth: 20"
Span from front of house to wall in question: 11'8"
Span from back of house to wall in question: 15'6"
Truss depth: 20"
