Counterbalance pulley - confined 1
jlawhorne
Computer
Jun 9, 2020
1
I'm having an issue.
I have narrowed down my options to a pulley system. I have a 31x65 mirror that will be acting as a door to a recessed cabinet. This will be latched at the top with push button to release. Once released, it needs to lower gently. I will likely use ball bearing drawer slides to control the movement, but to keep it from lowering too fast and breaking the mirror, I need a means of counterbalance. The interior space is only 4" deep but 30" tall. I need it to lower the full 30 inches and the mirror weights 40lbs. I have been thinking of using spring tension with a two pulley system. I would need this to operate at each end of the 65" spread for balance.
Any advice would be great and any links to materials would be greatly appreciated.
Counterbalance alone, like weight and pulleys, may not work for this application, since the mirror will be accelerating all the way down.
Perhaps you will need to engineer a simple friction mechanism that could have fine adjustment from outside.
"Where the spirit does not work with the hand, there is no art." - Leonardo da Vinci
Easiest way to do this would be to use a damper. McMaster has hundreds of sizes and configurations available.
