application of the rigid diaphragm property
Luis camposano
GT
A question:
Regarding the application of "Rigid Diaphragms" in a slab, when you have a roof with a part with a concrete slab and another with sheets, how is the diaphragm applied? Either the entire roof is taken or only applied to the area with concrete slab.
To give an example, the following figure
regards
What material are the sheets? The sheets seem like they should be applied as a line load along the slab edges.
Steel sheets. ...
Polycarbonate sheets. ...
Tile type sheets. ...
PVC sheets. ...
Acrylic Sheets
In the example the sheets on a cantilever structure.
The diaphragm is the concrete slab. Sheets should not be assigned to the diaphragm.
