John1991_09
I need help merging/aligning the plate elements above of the the rod elements so that the outer skin is smooth. I'll attach a picture of a section of my part so that you can see what I am referring too. I found a command online that allows you to "align line elements to plates" but I am unable to find this command in FEMAP. I also heard it could be done with the "adjust the plate offset" command but I'm not sure how to preform this correctly. Any help is greatly appreciated.
