Dear All,
The subject topic has been discussed extensively on many platforms but I see many contradictions between platforms, books and online literature.
I always like to refer to William Forsthoffer books about rotating equipment and compressors. In his book, he mentions that an increase in gas density (i.e. molecular weight) results in a reduction of gas relative velocity through the impeller which results in an increase in gas tangential velocity which in turn increases the head generated by the impeller for a given impeller tip speed. Also, the surge limit flow increases and the choke limit flow decreases resulting in a reduced stable flow range and a reduced turndown.
However, in the well known below head equation, the head is inversely proportional to MW meaning that in a case where MW increases and all the other parameters are fixed, the head decreases.
𝑯𝒆𝒂𝒅_𝒑𝒐𝒍𝒚 =((𝒌 * 𝒏_𝒑𝒐𝒍𝒚)/(𝒌 −𝟏)) * ((𝒁_𝒂𝒗𝒈 * 𝑹 * 𝑻_𝟏)/𝑴𝑾)*((𝑷_𝟐/𝑷_𝟏 )^(((𝒌−𝟏))/(𝒌 * 𝒏_𝒑𝒐𝒍𝒚 ))−𝟏)
With that being said, I have two questions:
1. I believe that the first relation which is explained in Forsthoffer's book is relating MW with the head developed by the impeller given a fixed tip speed. On the other hand, the head formula is relating MW with the head required by the compressor to achieve a fixed compressor ratio. Is my understanding correct or is there a real contradiction between the book and the formula regarding the head and MW relationship?
2. Forthoffer does not explain why does the gas relative velocity decrease with an increase in MW. The only way I see this relationship is that for a given impeller volumetric flow rate (constant flow coefficient) and impeller exit area, when the density increases, the velocity of the gas (i.e. gas relative velocity) has to reduce to keep the volumetric flow rate through the impeller constant. Is this understanding correct?
On a separate note but related to compressor impellers, Forthoffer mentions that in the old days, the first stage impeller used to be an open impeller since they can generate much higher heads than closed impellers due to the high stresses developed on closed impellers at high flow rates. I understand that he means that the volumetric flow rate at the first stage impeller is higher than the subsequent impeller stages hence, higher stresses are developed at the first stage impeller compared to subsequent impeller stages. Do you agree?
I was having a discussion about this issue (i.e. higher stresses at the first impeller) with one compressor OEM and he told me that in certain cases, the material for the first stage impeller must be of exotic material like Inconel 825 while the subsequent stages can be in Stainless steel depending on the H2S and chloride content in the gas and the stresses developed on the first stage impeller. I do not really understand this argument by the OEM. Does anyone understand the rationale behind the use of Inconel for the first stage impeller in these special cases?
Thank you in advance.
