Runoff flow rate from two drainage areas to one pond
Serene111
I was directing the runoff from two drainage areas to one detention pond, but the inlet flow at the pond doesn't equal to the sum of the runoff from the two areas. Could you please help me to understand what is wrong?
Serene
Remember that you're dealing with a hydrograph, and not a constant flow. When you add two hydrographs, the volume will always by the sum of the two (conservation of mass) but the peak flows will add only if they occur at exactly the same time. For details see
Peter Smart
HydroCAD Software
Got it, thanks, Peter.
