ACT script: Parametric Study-NamedSelection update when the geometry changes-DesignModeler
BriamV
PE
What is the way to create a NamedSelection that updates when the geometry changes?
I know how to create NamedSelection, the problem is when some geometric parameter changes and then another NamedSelection is created and the previous NamedSelection remains there, only a caution message appears since the edges that were part of the Named Selection no longer exist or are They changed their position, now I don't know how to solve that problem.
The procedure I am doing is as follows
def aftergenerate(feature):
Bodyy = ExtAPI.DataModel.GeoData.Bodies
inlett = Bodyy [0] .Edges [1]
ExtAPI.SelectionManager.NewSelection ([inlett])
named_selection = ExtAPI.DataModel.FeatureManager.CreateNamedSelection ()
named_selection.Name = "Inlet"
ExtAPI.SelectionManager.ClearSelection ()
that is why when a parameter changes, a new NamedSelection is created. I don't know how to make the NamedSelection adapt to the modified geoemtry.
