Contact US
ASTM A999 Secondary melting
I'm from a steel pipe manufacturer in China.
And for Clause 3.2 in ASMT A999, I am confused in understanding, the description as below:
3.2 If secondary melting, such as electroslag remelting or vacuum remelting, is used, the heat shall be defined as all of the ingots remelted from a single primary heat.
I am confused about the first word Heat, dose it mean Heat No. of the ingots after remelting is same with the heat no. of the primary heat? or the new diferent heat nos shall be redefined for all of the ingots after remelting?
Thanks in advance.
RE: ASTM A999 Secondary melting
Yes, it says that you are allowed to combine all of the re-melt ingots under the same heat number.
Personally I don't like this.
Our internal specs prohibited this practice and required unique identification of each re-melt ingot.
So they are usually marked as HT XXXXXX-1, where XXXXXX is the original HT.
In some cases I have bought multiple coils of material where some was the EAF/AOD material and some was then ESRed, same base heat number but marked with a suffix. And separate tests required.
P.E. Metallurgy
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
