Safety lock systems for lifting jacks
Hello all,
Do You maybe know any safety lock mechanisms producer, that has brochures or maybe cad drawings/models to download? I'm currently looking for a safety system in hydraulic jack, preferably a ladder latch or else like. However, all the systems that i have found are operated with pneumatics/electronics or include a slack cable/chain construction and I would love to avoid putting that into the jack. Is there any simpler solution with given dimensions, informations? Like even mechanically released lock before retracting the cylinder?
Thanks a lot, regards.
RE: Safety lock systems for lifting jacks
Railroad jacks use a pawl locking mechanism for any loads, but you will have to adapt it to your cylinder.
Pin thru a hole?
or a collar running down a threaded section on the rod.
Lifting Jack? Which one of the many types available should be coming to mind? If you're referring to an automotive type of floor jack a simple C-Clamp, clamped to one of the jack's frame rails with the clamp frame wedged between the frame and the lift arm will work for safety. If you doubt the ability for this to hold I've seen simple C-Clamps used to flip a large plate of steel with a crane. The plate was being made in to a new bolster plate for a large, body panel stamping press. If you're looking in to something like this, using the principle with a more impressive design should be fairly easy to come up with. Don't underestimate the clamping force of the screw and clamp frame. A C-Clamp with an elastic deformation strain gauge is eye opening to the frames effect on clamping force.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The New World of Thermoplastic Manufacturing
Digital-direct thermoplastic manufacturing offers exceptional quality, opens the door to novel design parameters not possible with injection molding while also bypassing the long lead time and up-front investment in injection molding tooling, offering a better total value proposition. Download Now
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
