heat transfer in an oven
I put a piece in an oven.
can I impose boundary conditions of the room and see the evolution of temperature on the surface of the piece ?
can I do that in COMSOL ?
RE: heat transfer in an oven
TTFN (ta ta for now)
I need tut this model in comsol , but I didn't know what physics exactly should I use to resovle the problem I told you before. what is the different if I use "turbulent flow" or "heat transfer in fluid" and what are the boundary conditions that I should put to enter that temperature profile.
