Unit of meaasure tm3/h
MarcoCryo
Industrial
Mar 8, 2020
3
Dear All,
can someone help me to understand what is tm3/h? How can I convert to m3/h?
I never see the same.
Bye.
A bit more context would help here.
What sort of values are they and what for?
what sort of numbers were you expecting?
Is is for a gas or a liquid? At any sort of pressure?
Is it in English?
tm3/h?
I think all will agree that m3/h is cubic meter per hour. The t is the question mark. The t is often internationally used as abbreviation for ton, and accepted as symbol for this (1t=1000kg) together with standard SI-units. (Same for hour h=3600 SI seconds).
This is probably the nearest you can come to official standards. What tm3/h means in your context has to be explained by the person using the unit if it is not self-explaining.
