Lateral grip: Optimize for wheel bump travel or shock stroke?
ErikPSS
Context
Reverse trike on double-wishbone IFS with coilovers
Objective
Improve lateral grip
Decrease roll
Method
Reduce load transfer
-decrease CG
--lower ride height
Current static ground clearance: 6"
Target static ground clearance: 5"
Current static ground clearance of 6" - target static ground clearance of 5" = 1" drop @ wheel * 0.84375 motion ratio = 0.8" @ shock
Current 16" extended shock rides at 15.5" - 0.8" = 14.7" new shock ride
Replacing with a threaded body shock of the same 16" extended length (11" collapsed / 15.87" extended) gives:
15.87" extended - 11" collapsed = 4.87" usable stroke
14.7" - 11" = 3.8" bump / 4.87" usable = 75% bump
15.87" - 14.7" ride target = 1.2" droop / 4.87" usable = 25% droop
Replacing with an 18" shock (12" collapsed / 17.87" extended), travel would be limited by packaging to 17 1/8". However,
17.125" packaging - 12" collapsed = 5.125" usable stroke
14.7" - 12" = 2.7" bump / 5.125" usable = 52% bump
17.125" - 14.7" ride target = 2.5" droop / 5.125" usable = 48% droop
Does that look right?
What would you do for a 100% street performance vehicle: 3.8" bump : 1.2" droop, or 2.7" bump : 2.5" droop?
First thing I'd want is a set of tires with more grip. You can drop the c.g. with a rim change while you are at it.
Get a VBOX and measure some key performance indicators (understeer, steering gain, max lat) and run a constant radius or constant steer test. Results from this will help you gauge your changes even with the tire you have. You might even need more motor to get more grip.
Agree with Brian. Consider adding a soft bump stop as well.
