How to delay a function
Aange
I'm trying to figure out how to delay a function "IF(MODE-5:varval(launch_force),varval(static_force),varval(launch_force)" this function is used to propulse a marble thanks to a spring.
But at the moment the spring launch at the begining of the simulation and not when the marbles arrive.
I need your help !
PS : You can find a screen shot of my project, I don't know if it help
 https://files.engineering.com/getfile.aspx?folder=bf28cd7b-1d37-405a-94f4-80fc8530f79b&file=Marble.png
One way to implement a delayed action is to use a STEP function based on time.
STEP
The STEP function approximates the Heaviside step function with a cubic polynomial. It has continuous first derivatives. Its second derivatives are discontinuous at x=x0 and x=x1.
Format
STEP (x, x0, h0, x1, h1)
Arguments
x
The independent variable. It can be a function expression.
x0
A real variable that specifies the x value at which the STEP function begins.
x1
A real variable that specifies the x value at which the STEP function ends.
h0
The initial value of the step.
h1
Cheers
Greg Locock
Thanks for your answer.
I tried with the function step with this "STEP(varval(launch_force),varval(static_force),varval(launch_force), 1.45 , 0 , 1.50 , 1 )" as I want the spring to lunch the marble at 1.45 and be ready for the second one at 1.50.
However my model still doesn't work, the spring is still activeted at the begining of the simulation.
what did I do wrong ?
