text value to numeric value - solidworks custom property
thread559-265073: Give value to cus.prop. with equation.
hi,
is there a way to change the custom property type from text to numeric using equation?
example - i have a custom property "TEST" with type as 'text' and value as "YES".
and i need the another custom property "TEST1" with type as 'text' and value as "1" if the custom property "TEST" has value "YES" and "0" if the custom property "TEST" has value "NO"
it is something similar to the thread link i have mentioned above.
i dont want to use API but something that can be figured out using equations.
thanks in advance.
RE: text value to numeric value - solidworks custom property
thanks Scott, i am using property tab builder to control the equation based on conditions. thought it would be helpful if i use driveworks xpress to feed the input.
thanks for your suggestions.
Sundar.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
