Repeat Last Command
catiaUSR
Aerospace
Hey!
Does anyone know how I can setup a Creo Map Key (hot key) to repeat the last command? For example, if I hit the Assemble button then I close the Assemble window, I would like to be able to hit 'a' or 'b' etc on the keyboard and for that to open the Assemble window again.
Mapkeys replay existing Creo commands. Unless PTC creates a "do last command" function there is nothing for a mapkey to replay.
Bummer. They should hurry up and do that..
Don't hold your breath.
Last command functionality does not play well with a WIMP interface, it does a lot better when you are using a command driven interface.
Think Windows GUI vs Command prompt window.
Ben Loosli
