Good day everyone,
this topic is about my project which is "construction of retaining wall" with a height of 4 meters, and 10 meters long. its footing has a base width of 2 meters, base length of 10 meters and a thickness of 0.60 meters. During our concrete pouring i told my workers to use class B mixture when in fact the design mixture is Class A (1:2:3). Before the material engineers came to inspect the site for concrete pouring, i told them to use class A so they used it. When the materials engineer have tested the concrete in cylindrical mold, the result was shocking because it fails. and it is far from the design strength which is 3500 psi. Note that payment for this project doesn't applies to weak actual concrete strength so we did another testing through hammer test. The result was another tragedy again which is 1500 psi, it failed, and it doesn't meat the design strength which is 3500 psi so the result for this project is either retrofitting or no payment otherwise, remove and replace. As a contractor, i want to retrofit in an economical method. as advice to me from the agency, i need to retrofit and test again the concrete (new structure of retrofitting). My question is what is the best method to retrofit the said retaining wall for the sake of my capital and gained even the structure seems needs to remove and replace as this actual strength which is ranging from 1000 psi to 1500 psi can not match the required design strength which of 3500 psi? do you have any suggestion? note: the retaining wall's face is a lot boundary so additional volume of concrete doesn't apply in the retaining wall face.
MARL2017
MARL2017
