JamesWayne
Hello Ladies & Gentlemen,
I have a question regarding this shear wall that I wish to analyze. In order to find the amount of jamb steel needed for the left and right shear wall, I need to know how much dead load is on the wall to resist overturning. Should I consider only the wall weight and half the span of the slab to the next interior wall as my dead load or can I use more? Since this structure is divided up into cells, I am quite confused has to how much weight I can use. The interior walls are load-bearing, but since the strip footing is only around the perimeter of the structure, I assumed that most of the weights won't transfer to the left and right shear walls. Please let me know how I should continue analyzing this structure.
Much appreciated!
Much appreciated!
