ANSYS CFX multi domain modeling
pegus
Aerospace
MX
Good day,
I am trying to model a bubble decompression inside a tank. This tank is half full with water and the other half is air. I have some questions regarding the set up of this problem.
The intention of the bubble has an initial pressure of 50psig and then it drops to 0 psig at 0.1 seconds. I was planning to create this variation with some expressions.
The intention of this analysis is to get the water pressure distribution on the tank walls.
1.- To start with the bottom half with water and the upper part with air, do I need to create 2 domains? or how can I specify this condition.
2.- What would be the best inlet conditions for the bubble? (pressure or velocity)?
Thanks in advance,
P.P
