Offset Surface - Macro
DomKum
Automotive
Nov 27, 2005
23
Hi Experts,
Below is the Macro which will offset the all the surfaces in the selected GS.
I have two issues in which I need guidance/help
1. All the surfaces to be offset based on the user request Like - In / Out. Currently its happening on the side based on iorientation = True/False.
2. Ignore the element which is failing by deactivating and go to next
---> Here even though I have included "On Error Resume Next" - upon fist encounter of error element - MACRO is not able to update the successful element
Language="VBSCRIPT"
Sub CATMain()
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set hybridBodies1 = part1.HybridBodies
Offsetvalue = Inputbox("Enter the value offset")
Dim InputObjectType(0)
Set hybridBody1 = hybridBodies1.Add()
Set hybridBody1 = CATIA.ActiveDocument.Part.InWorkObject
msgbox ("Select the geometrical set")
Set oSelection = CATIA.ActiveDocument.Selection
oSelection.Clear
InputObjectType(0) = "HybridBody"
Status = oSelection.SelectElement2(InputObjectType, "Select Geometrical set.", True)
Dim iCount
Dim i 'As Integer
oSelection.Search "CATGmoSearch.Surface,sel"
iCount = oSelection.Count
For i =1 to iCount
'-----------With the statement as below each item name in the selected GS will be displayed
Set USel = CATIA.ActiveDocument.Selection
'MsgBox(USel.Item(i).Value.Name)
'--------------- 09-Macro_to_display_selected_items.catvbs - reference macro for this statement
Set hybridShapeFactory1 = part1.HybridShapeFactory
Set hybridShapeSurfaceExplicit1 = oSelection.Item(i).Value
Dim reference1 'As Reference
Set reference1 = part1.CreateReferenceFromObject(hybridShapeSurfaceExplicit1)
Set hybridShapeOffset1 = hybridShapeFactory1.AddNewOffset(reference1, Offsetvalue, True, 0.010000)
hybridBody1.AppendHybridShape hybridShapeOffset1
part1.InWorkObject = hybridShapeOffset1
If Err.Number <> 0 Then
Selection.Clear
Selection.Delete
End If
part1.Update
Err.Clear
Next
part1.Update
msgbox ("Total number of surfaces offseted are " &iCount)
End Sub
