Non Standard Forging MOC (SA350-LF2 CL1 vs SA765-II)
mechmania
35
Dear Friends,
Reference:
On High Pressure Vessel where we specify Self Reinforced Nozzle (Other Than STD ANSI LWN) which are mostly Non Standard Forging (Barrel Nozzles).
These Barrel Nozzle can be constructed from Welding 2 Pieces (Boss Welded to FLANGE) or can be made as one piece construction for Barrel and Flange .
DP: 1400 Psig
MDMT: 20F
Question:
1) If it is Made of Two Piece construction (boss welded to Flange), Can the Boss MOC be SA350-LF2 CL1 same as Flange?
2) If it is Made of One Piece Construction than Can it be all SA350-LF2 CL1?
My Understanding was, in Two piece Construction Boss Should be SA765-II and Flange Will be SA350-LF2 CL1.
And in one piece construction the Whole Forging(Boss and Flange) should SA-765-II.
As I read SA-350 is for Piping Components while SA-765 is for Pressure Vessels.
Please share your experience.
Mechmania
mechmania, SA-350-LF2 is widely used for both of your proposed constructions in Sec VIII, Div. 1. SA-105 may be used in some cases. In my experience SA-765 is imposed by client specs, not by Code.
Mike
Thank you SnTMan for quick response.
When i read through the specs I see them as most Identical.
See attached comparison I found that some has put together.
So what prompt these client requirements?
Is there some technical advantage of using SA765-II over SA350-LF2 Cl?
Best regards,
Mechmania
 https://files.engineering.com/getfile.aspx?folder=33859090-2925-4ddb-88c8-df085c1bfac2&file=SA765_-VS-350LF2_Copy.pdf
mechmania, it may be that for the larger forgings testing per SA-765 (Sec 6) is advantageous. I really see no particular reason to pick one over the other , except perhaps that SA-350 is widely available.
