SolidWorks API Dimension Sensor Value
Good Evening,
I'm trying to write a SW script in VBA to automatically output the length of a line (defined in a sketch).
To make things easier, I created a dimension sensor for the length of the line (since it is a complex shape).
I keep getting the error: "Object doesn't support this property or method" on the same line of the code even though I'm following the SW help very closely (I get the error when running the sample script too).
Here's the script (with the line giving the error highlighted):
CODE
Option Explicit
Sub main()
    Dim swApp As SldWorks.SldWorks
    Dim swPart As SldWorks.PartDoc
    Dim swModel As SldWorks.ModelDoc2
    Dim swFeat As SldWorks.Feature
    Dim swSubFeat As SldWorks.Feature
    Dim swSensor As SldWorks.Sensor
    Dim swDimSensor As SldWorks.DimensionSensorData
    Dim sensorValue As Double
    Dim text As String
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    Set swFeat = swModel.FirstFeature
    Do While Not swFeat Is Nothing
        If (swFeat.Name = "Sensors") Then
            Set swSubFeat = swFeat.GetFirstSubFeature
            Do While Not swSubFeat Is Nothing
                Set swSensor = swSubFeat.GetSpecificFeature2
                swDimSensor = swSubFeat.GetSensorFeatureData
                sensorValue = swDimSensor.sensorValue
                text = (text & (swSensor.Name & ": " & sensorValue))
                Set swSubFeat = swSubFeat.GetNextSubFeature
            Loop
        End If
        Set swFeat = swFeat.GetNextFeature
    Loop
    MsgBox (text)
End Sub
Thanks in advance for your help!
RE: SolidWorks API Dimension Sensor Value
Why not just add a driven dimension in the sketch and then get it (and its value) using ModelDoc2::Parameter?
Dim swDim As SldWorks.Dimension
Sub main()
Set swDim = swApp.ActiveDoc.Parameter("SomeDrivenDimension@AComplexSketch")
MsgBox "Value is: " & swDim.GetUserValueIn(swApp.ActiveDoc)
End Sub
Wow! Thanks! Somewhere along the way I forgot about that possibility!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
