Contact US
CIP implications on tank design
Imagine I have an atmospheric tank with ambiant temperature product in it.
It will be routinaly CIP'd in different steps with Hot water, Hot caustic and Cold desinfectant.
What specific design considerations should I consider?
RE: CIP implications on tank design
is it made from carbon steel, stainless steel, fiberglass, etc?
What are the actual temperatures of the hot and cold fluids? A P&ID would help us understand your situation much better as well.
Stainless steel, vertical, < 30000 litres, conical bottom.
Temperature: hot is 80C, cold is 18C.
Off the top of my head, you'd need to consider the CIP process temp/pressure and see how that corresponds to your MAWP and design temperature and adjust as needed. Depending on those values you may need a relief valve to protect the tank. Is the tank rated for full vacuum? How is the CIP process controlled and what happens if those controls fail?
Thank you for the guidance !
My understanding is that there are different ways to prevent tank failure due to overpresure or vacuum
- tank design: design for vacuum and overpresure (despite this being in use at atmospheric pressure)
- instrumentation : vent, pressure relief, vacuum relief valve
Would all of the above be applicable here?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
