I'm searching for a valve that has the same working principle as the ones in the water tank of Nespresso coffee machines, meaning that i can "snap" a container in its place and remove it without using additional "unlatching" operations (like in the quick release coupling, where a lock ring has to be depressed) and the valve is opened by a physical feature that displaces sealing element (not by pressure differential).
I want to incorporate the same principle in my design where the fluid tank can be connected and removed easily and quickly, but i cant find anything useful so far.
SD
SD
