Contact US
stop-drilling / end-drilling / ??? Drilling to stop crack from growing during welding
What is the correct terminology for drilling a hole to arrest a crack?
This is done typically a little bit further than the end of a crack, in order to avoid that the crack grows further during heating (grinding, preheating, welding, ...).
Is "stop-drilling a 5mm hole 20mm beyond the visible end of the crack" something that I can put on a repair welding procedure?
RE: stop-drilling / end-drilling / ??? Drilling to stop crack from growing during welding
I suppose "drill a 5mm hole 20mm beyond the visible end of the crack" is perfectly understood
luis
I would agree with just "drill;" "stop-drilling" is confusing, on its own. Seems to me there was confusion about the intent of the hole, vs. a command to make a hole.
TTFN (ta ta for now)
I'll go with just "drilling" then. Thanks for your input!
to be precise an xray of the crack is performed.
then the developed negative is used to find the location.
dye penetrant can also be used.
a crack can be subsurface or surface it will dictate method.
wording will be to drill out crack and reweld if in a weld.
in parent material a non visible crack depending on the requirements will have to be precisely removed,
or if acceptable can have a drill hole at the base, then repaired.
the driver is the requirements.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
