NX native set part Read only
Lars1978
NL
Hi Guys,
Can I set a part read only in NX?
(I know I can do this in the windows explorer)
Lars
Lars
NX native (NX13 or NX1847)
Solid Edge ST10
Inventor
Solidworks
Newer versions of NX have an option to password protect a file; otherwise, basic file permissions for native NX are handled at the OS level.
www.nxjournaling.com
Unless of course if you're using Teamcenter to manage your data, then you'll have lots of options.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
That wouldn't be native NX then (as specified in the thread title)...
Sorry, I missed that nuance ;-)
Irvine, CA
Siemens PLM:
UG/NX Museum:
Of all the things I've lost, I miss my mind the most.
Irvine, CA
Siemens PLM:
UG/NX Museum:
Can you try this:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Togggle_ReadOnly
    Sub Main()
        Dim s As Session = Session.GetSession()
        Dim ufs As UFSession = UFSession.GetUFSession()
        Dim theUI As UI = UI.GetUI
        Dim lw As ListingWindow = s.ListingWindow()
        Dim workPart As Part = s.Parts.Work
        Dim RemUtil As RemoteUtilities = NXOpen.RemoteUtilities.GetRemoteUtilities()
        Dim FilePath As String
        Dim ufp As UFPart = ufs.Part
        Dim modified As Boolean
        ''lw.WriteLine("Work      : " & workPart.FullPath)
        FilePath = workPart.FullPath
        If RemUtil.IsFileWritable(FilePath) = True Then
            ''lw.WriteLine("File is WRITABLE")
            modified = ufp.IsModified(workPart.Tag)
            If modified Then
                If theUI.NXMessageBox.Show(workPart.Leaf & ".prt", NXMessageBox.DialogType.Question, "The Part you want to set ReadOnly is modified." & _
                                           vbCrLf & "Please save your part first if you want to keep the changes." & _
                                           vbCrLf & "Are you sure?") = 2 Then
                    theUI.NXMessageBox.Show(workPart.Leaf & ".prt", NXMessageBox.DialogType.Information, "Exit Script." & vbCrLf & "No attribute changed.")
                    Exit Sub
                End If
            End If
            RemUtil.SetFileWritable(FilePath, False)
            'check if changed
                ''lw.WriteLine("FAILED: File is LOCKED")
                theUI.NXMessageBox.Show(workPart.Leaf & ".prt", NXMessageBox.DialogType.Error, "Failed: File is LOCKED")
            Else
                ''lw.WriteLine("Attibute changed: File is READ-ONLY")
                theUI.NXMessageBox.Show(workPart.Leaf & ".prt", NXMessageBox.DialogType.Information, "Attibute changed: File is READ-ONLY")
            End If
        Else
            ''lw.WriteLine("File is READ-ONLY")
            RemUtil.SetFileWritable(FilePath, True)
            'check if changed
            If RemUtil.IsFileWritable(FilePath) = False Then
            Else
                ''lw.WriteLine("Attibute changed: File is WRITABLE")
                theUI.NXMessageBox.Show(workPart.Leaf & ".prt", NXMessageBox.DialogType.Information, "Attibute changed: File is WRITABLE")
            End If
        End If
    End Sub
End Module
