Contact US
Distance between two circumferential welds in a pipe
Hi everyone.
In API 1104, ASME or some other standard, is it specified what is the minimum distance between two circumferential welds in a pipe?
Thanks in advance
RE: Distance between two circumferential welds in a pipe
Do a search on this site as it comes up a few times s year, e.g https://www.eng-tips.com/viewthread.cfm?qid=370184 ams follow a few of the links.
AFAIK, the is no code limit, only company standards and specifications.
Care to expand on your problem?
Apparently, this data is not specified in any standard.
Thank you very much for the help.
You get to exercise your engineering judgement.
“What I told you was true ... from a certain point of view.” - Obi-Wan Kenobi, "Return of the Jedi"
Normally, experience says 50mm minimum, to have a safe HAZ.
lm
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
