Slang/Jargon
Slang/Jargon
"Drop Beam" or "Dropped Beam" ?
"Screen Porch" or "Screened Porch" ?
"Footer" or "Footing" ?
I use the latter in all cases.
What do you use?
What do you use?
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
https://www.daredictionary.com/
While some of these may not make technical or grammatical sense, some of them do follow speech patterns that are common in some parts of the country. And it often those patterns that drive our speech.
P.E. Metallurgy
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
get me a phrase with each Slang/Jargon above please. Thank you
luis marques
RE: Slang/Jargon
See also the common American term "Skim milk", which is a pet peeve of mine.
Steve
RE: Slang/Jargon
luis
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
I'll allow it. [spoken like a judge who has final authority (from my position of zero authority) ]
https://www.collinsdictionary.com/us/dictionary/en...
(2B)+(2B)' ?
RE: Slang/Jargon
TTFN (ta ta for now)
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
And then I get annoyed, because what they are describing isn't "advanced", it is at best "contemporary" or "state of the art".
Steve
RE: Slang/Jargon
I remember, as a freshman at Lehigh U, "The Engineers" back then, how many freshmen had to take remedial English (and math to a lesser extent). I've probably forgotten more that I've remembered, but I bless that battle axe, Mrs. DeTurk, who drilled into us "miserable seniors full of senioritus" the English we had failed to properly learn. If you can't retain it, have you really learned it?
As far as Slang/Jargon goes, I cringe at "irregardless," since that word would mean "not without regard, which is the negative of how it is usually intended.
Beyond that, I've enjoy auditing the banter above, pedantic or not, with a twinkle in my eye, at thoughts of water cooler repartee of times past.
Skip,
Just traded in my OLD subtlety...
for a NUance!
RE: Slang/Jargon
screen door vs screened door;
drop panel vs dropped panel.
While proper English suggest the later is correct, I never seen or heard the later used.
RE: Slang/Jargon
RE: Slang/Jargon
Ted
RE: Slang/Jargon
Skip,
for a NUance!
RE: Slang/Jargon
screen or screened door, both are correct in the right context, as is drop panel or dropped panel .
ie, a screen door in a door that has been screened to add protection.
Screen door - Wikipediaen.wikipedia.org
A screen door can refer to a hinged storm door (cold climates) or hinged screen door (warm climates) covering an exterior door, or a screened sliding door used with sliding glass doors
RE: Slang/Jargon
-Calling any wide flange member a "beam" regardless of use/orientation.
-Calling spherical pressure vessels "spears".
-Using the term "torqued/torquing" for tightening bolts when one really means "tensioned/tensioning".
-Using screw and bolt interchangeably and/or backwards.
-Spelling numbers 0 < x <= 9 then using digits above that... I don't care what our grammar teachers said way back when, numbers are made of digits, not letters (even in hex or something like that, the letters function as digits)
RE: Slang/Jargon
RE: Slang/Jargon
Also, in most cases, the flange on an 'I-Beam', as compared to the height of the beam, is generally not as wide as would be the case with the 'Wide Flange Beam', which I guess is part of the reason why they call it a 'Wide Flange Beam' in the first place.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
RE: Slang/Jargon
We don't have tension wrenches; we have torque wrenches; they measure torque applied to bolts. So torquing a bolt is what you are doing, since that's measurable, while the induced tension is not.
RE: Slang/Jargon
RE: Slang/Jargon
Some others (as this appears to have turned into a list of our pet peeves...) are:
Worse case vs. worst case.
Footer vs. footing.
Masonary vs. masonry. (why....how...?!)
Cement vs. concrete.
Epoxy vs. adhesive (not always interchangeable).
Suspended slab vs. elevated slab.
Sheer vs. shear.
Stirrups vs. ties/hoops (column/wall application)
Ties/hoops vs. stirrups (beam application) I believe there is an entire thread dedicated to this one...
Tor-jzhun vs. tor-shin.
Joistuses (???) vs. joists.
Rafter vs. joist. (ceiling application)
# 1 vs. #1
ha ha vs. haha
??? vs. ? (Shop drawing review, for example. ??? at the end of a correction seems like an accusation)
And for the love of all that is holy: 2020.27.04 vs. 2020.04.27!!!!! The latter (amazingly!?!) will allow file folders or pdfs or whatever to be in the correct order. The former will cause absolute chaos and anger.
Latter or bust...
RE: Slang/Jargon
RE: Slang/Jargon
or joises (sp?)
Dik
RE: Slang/Jargon
Crush and Run is another one of my favorites (Crusher Run)
@Dold - I say both "Suspended Slab" and "Elevated Slab".
RE: Slang/Jargon
Ted
RE: Slang/Jargon
RE: Slang/Jargon
My glass has a v/c ratio of 0.5
Maybe the tyranny of Murphy is the penalty for hubris. - http://xkcd.com/319/
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
Ted
RE: Slang/Jargon
Does anyone else call bolt cutters "mojos"?
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
Irvine, CA
Siemens PLM:
UG/NX Museum:
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
Diags or dikes (a portmanteau of "diagonal cutters") is jargon used especially in the US electrical industry, to describe diagonal pliers.
Irvine, CA
Siemens PLM:
UG/NX Museum:
RE: Slang/Jargon
RE: Slang/Jargon
RE: Slang/Jargon
Even when CC is done post-production, as in a movie or TV show, the actors/directors often go off script, so CC doesn't match in those cases as well. Or worse, the spoken language isn't even English, but someone CC'd it for English, and the neither the English dub nor CC match what was originally said in the original language
