Ball and Butterfly valve design in application for Hydropower industry
Hello.
I am interested in design of the ball and butterfly valves that used in hydropower industry. Such valves installed in front of the turbines in hydropower plants. Which standards and/or literature describes the following: Stress analysis of the valve housing, counterweight design and hydraulic design of the valve based on the flow rate?
Thank you in advance,
Sergey
Sergey
RE: Ball and Butterfly valve design in application for Hydropower industry
The strength analysis is performed, for example, according to EN13445-3.
The size of the counterweight must be determined by the braking force in the hydraulic cylinder.
- The braking force is equal to the closing torque divided by the arm.
- the closing torque is equal to the torque from the counterweight plus the hydraulic torque minus the bearing friction minus the friction from the seal.
- hydraulic torque see. link: https://met-calc.com/index.php?stranka=sphericalva...
The minimum and maximum pressures in the hydraulic cylinder must be checked.
Thank you for reply and comprehensive explanation.
Best regards,
Sergey
